I bought 2 velocity subs and 2 amps (300rms and 600max) and 4 5x7 speaker and a amp (4x100 Rms).  I need to know which cap to buy or which alternator. PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  :'(
Nismofreak School account.
well for sure you'll need a 4 gauge amp kit for all three amps at the minimum. we'd need to know your car make and model to see what's the biggest alternator you can do. but by the specs you have given for you amps you might be okay with your factory alternator. as for the caps get 1 cap per 1,000 watts. heck get a 5 farad to be safe.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
get everything hooked up first, i'd do another alternator last, you might not even need one.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
judging from the info as stated before you probly wont need a new alt.
Im running 2400watts RMS and im currently on Stock ALT and stock Batt. I had to change my original 063 battery as it died in 6 months but now i have a 065 and its not even cutting out.
As long as ur wires are fine i think you would be ok.
yeh get an optima or a kinetik battery and do the big 3 and you will probably be okay.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
and how bad is ur voltage drop? u aint giving that amp the power it needs considering ur alt is prolly less than 140 and that amp alone pulls prolly over 200.
well that amp probably will only pull 100 amps from the car. probably less than that. i forgot the calculator i used somewhere but it can tell you how many amps are being drawn from your alternator
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
