punchy Posted January 22, 2016 Report Posted January 22, 2016 Ok so I got a new car after crashing my other one finely lol 2012 ford fusion se problem i have is that my amp is cutting out when I turn the volume up and then turning back on when i turn it down from voltage drop so I was thinking deep cycle battery but dont no if that well help at all also going to put big three I want to add Alternator but that well be last after I do the battery and big three.... 1/0 gage wire and audiopipe apcl 18001d watt amp 2 sundown sa 12s if anyone can give me some help on how to fix my problem please help me
reedal Posted January 22, 2016 Report Posted January 22, 2016 For starters, where did you ground your amp at? Are you sure it's a tight, wiggle free connection? How did you set your gain? And are you using the "bass boost" setting? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
punchy Posted January 22, 2016 Author Report Posted January 22, 2016 I sanded the metal bear no pain i grounded it in the trunk wall and I used a boat with a lock nut no wiggle whatsoever the gain is not even turned up a quarter of the way in everything else is turned all the way down no bass boost
reedal Posted January 22, 2016 Report Posted January 22, 2016 I'd say that's probably not a good place to ground, and a bad ground will definitely cause an amp to cut off when it's trying to draw more current than the ground can support. If you can, try and ground it directly to the chassis, or run a length of 1/0 wire to your front battery ground. Some people suggest grounding to a strut tower, but with no personal experience of that one, I don't know how good of a ground it really is. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
punchy Posted January 22, 2016 Author Report Posted January 22, 2016 Haha wow that just happened I moved the ground wire and working grate cant believe I made that rockie mistake thanks bro now its time to build a new box
reedal Posted January 22, 2016 Report Posted January 22, 2016 No problem. Good luck SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
