SLYSS Rockford Fosgate Install **AUS** LS1 V8 -- D2I Automotive
More about the CNC build! What do you use for your control? How do you write your programs?
i use a desktop computer with mach 3 and serial port out to the stepper motor controller cant remember the exact model. I design all my models in either inventor and do it that way or if speakers/ "2d" cnc machining parts then i just do it all in cam bam and export to gcode then load into mach 3 set the zero points and hit start :)
alright so one is done! well 90% have to wire it up and do the logo panel and lighting but its on and looking pretty haha heres the pics of the progress shots:
Base coat:
Cleared:
And on:
Hopefully get some more done next time i get a day off work :)
Getting some time off on Tuesday so might get a perspex panel on and some edge lit plexi going but need to install all the airbag suspension gear in the boot to be able to start wiring up where everything goers and then install the amps so hooking the speakers up will be a little bit off yet :/
Paintworl looks schmick mate
cheers mate :) left it cure for 24 horus then put it in the car... got a hot day and car was all locked up :/ reacted in 1 little are right on the top enough to annoy me but i really cbf sanding it all back and painting again so it will have to stay
