Wiring or tuning seem obvious, but that doesn't explain the bottoming out.....are you positive the port has enough room to let air through...you may be choking the sub....I would say with that set up you will see at least 143 on a tl, so something is definitely wrong.
Edited by littleitaly1990
A vitrolic, megalomaniacal sadistic psychopath.
Not to sound like and idiot, but how would I go about testing he coil and what is DMM?
DMM = Digital Multi Meter - measure the resistance of the coils. For a Dual 2 it should be ~1.7 ohms each coil I think.
I think you could do with more port area. I'm sure that port is WAY too long, for some reason or other, although it does give tuning of about 34hz.
Also check the gains on the amp :)
10.x volts fo' life!
Guest MegaloManiac
This is a ROUGH drawing of how shit is wired, any questions ask me and i will explain.
Im a little OCD about peoples Paint skillz. Seems like you didn't try at all. Here is my translation of yours, Is this correct?
Edited by MegaloManiac
