bmxnitro Posted February 3, 2016 Report Posted February 3, 2016 so i have a Sq Hds215 and i need a new box, something that gets lower, moves more air, and preferably a interchangeable port. i have a apcl1500 running it and it will be in a 06 uplander any ideas?
Joe X Posted February 3, 2016 Report Posted February 3, 2016 Do you know the specs of your current box?
bmxnitro Posted February 4, 2016 Author Report Posted February 4, 2016 33W 19D 17T port 3.5W 30in L 16.5H
Joe X Posted February 4, 2016 Report Posted February 4, 2016 Box specs are as follows 3.7 net @ 32.5Hz bout 54 square inches of port area BUT a slot port would need to be 15.5" height not 16.5". Do you have any pics? Is it sub/port back? Are you running the sub at 2 ohm?
bmxnitro Posted February 4, 2016 Author Report Posted February 4, 2016 yeah its 15.5 its front fron at 1 ohm not hooked up rn
Chris Braun Posted February 4, 2016 Report Posted February 4, 2016 With a new ox, make sure you muzzle it until it is familiar with you and you with it. Also make sure you take the muzzle off when it grazes.
bmxnitro Posted February 4, 2016 Author Report Posted February 4, 2016 With a new ox, make sure you muzzle it until it is familiar with you and you with it. Also make sure you take the muzzle off when it grazes. ty i wasent sure about that XXDD
Joe X Posted February 4, 2016 Report Posted February 4, 2016 yeah its 15.5 its front fron at 1 ohm not hooked up rn Le'ts see a pic, you should fire sub / port back if both on the same face.
bmxnitro Posted February 4, 2016 Author Report Posted February 4, 2016 http://i.imgur.com/5krjCf6.png
