2012 Toyota 4Runner SQ+ build
You may not meet Stock for MECA. Have to check new rules.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I'm going to be competing Street. Only speaker mod is the tweeters in the pillars. The other speakers (other than the subs) are all factory sizes in factory locations. Also, no mods to the dash.
It's five degrees outside. It's a good day to stay inside and wrap some panels. :D
16572121-89AA-4407-8551-2A0DCFF210CF_zps
0E7262F6-7125-48D9-A4BE-AB5A8AB394DF_zps
Today was rough, I had to heat up the electrical tape every time I used it.
The good news, my drink stayed cold. :D
21D1856B-6758-409F-B44C-4D5CBC2FD4B7_zps
Hope everyone isn't getting sick of my updates, here is today's progress.
BD15DE23-1295-412B-B908-A9AD699A379D_zps
84AFE9D8-3D90-435B-95D2-3EB5542575D6_zps
Next I started working on the flux capacitor.
72EEE73F-0CB1-4870-820E-6E3CE552CC90_zps
E752A49B-9939-481E-BA10-C36F0BF83716_zps
AA109079-7371-4F42-96DE-2CFC3B615F77_zps
I worked on the car for six or seven hours today and feel like I got very little accomplished.
I color coded all of the speaker wires.
2E3A2462-A3FC-4753-B808-861BECD22CF5_zps
I then wrapped them in techflex and color coded those.
163EF12D-54B0-425D-B16F-5E6B80FB462C_zps
FED00168-6E56-40F9-AC05-E510B605BD42_zps
Next I made a box to match the flux capacitor to house the speaker connections and the SMD fan controller.
E00828B7-A648-45E5-A302-27154F87A5E5_zps
This picture shows the terminal box, it also shows that I covered the flux capacitor and added acrylic.
740136EE-8422-4F3F-A394-12FF3D0162BF_zps
Next job was attaching the grounds. This is prior to techflex.
39089032-ACE2-42E5-B44F-164B8B93F2F5_zps
So many wires and so much tech flex...
759B9E6B-4EBC-4E01-B11A-4F5EAB569DB9_zps
3358DB33-D006-49F2-AD40-95A63A6C699C_zps
if you have an issue or need to service something how are you going to remove the fuses?
I'll remove the cover panel and the piece holding the plexiglass. Should take less than a minute.
thats A LOOOONG time if something catches fire....
Fuses are suppose to pop first but that does not always happen and that is your fastest power disconnect point unless you have a breaker or fuse under the hood as well
There will be a fuse under the hood within 18" of the battery.
I have that 3 way set on an MS-8 as well be careful my MS-8 randomly decided to blow up a tweeter you can not get replacements from PPI/Soundstream
but a decent 3 way indeed I had to cross the MID-BASS fairly high they give good midbass but can't take much power before bottoming out unless I crossed them over in 120+ hz range
