BigHOUSTON Posted February 6, 2016 Report Posted February 6, 2016 Looking for ideas on amps for what i need. Got an x15 d2 plan to wire to 1ohm with an upgraded coil, rated a 2500w rms. I dont necessarily have the electrical to run that much power. I have a 150a stock alt with a xs d3400 up front. Im looking to stay between 1500-2000w. Also to be taken into consideration, i will also be running a little alpine 50.4 but only running front 2ch.
reedal Posted February 6, 2016 Report Posted February 6, 2016 I would suggest getting electrical up to par before any amplifier buying personally. Get a quality alt first if you're able to, one that puts out ~200A at idle. And then a battery for the rear close to the amp. You can do a large group 31 or similar, or if space is an issue, you can do a smaller battery. With my 270A hairpin (200A at idle) D3400, and D4700, amp rated for 2600@2ohms where I'm wired, I drop to 13.5-6 on songs with long bass notes. But as far as amp recommendations go, sundown seems to be the more popular choice, or a DC 2k, ampere, etc. The same brands that are recommended on a daily basis pretty much. You didn't say what coil configuration you have, so no clue what resistance you plan to wire it to SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
BigHOUSTON Posted February 6, 2016 Author Report Posted February 6, 2016 I would suggest getting electrical up to par before any amplifier buying personally. Get a quality alt first if you're able to, one that puts out ~200A at idle. And then a battery for the rear close to the amp. You can do a large group 31 or similar, or if space is an issue, you can do a smaller battery. With my 270A hairpin (200A at idle) D3400, and D4700, amp rated for 2600@2ohms where I'm wired, I drop to 13.5-6 on songs with long bass notes. But as far as amp recommendations go, sundown seems to be the more popular choice, or a DC 2k, ampere, etc. The same brands that are recommended on a daily basis pretty much. You didn't say what coil configuration you have, so no clue what resistance you plan to wire it to 1ohm
reedal Posted February 7, 2016 Report Posted February 7, 2016 I would suggest getting electrical up to par before any amplifier buying personally. Get a quality alt first if you're able to, one that puts out ~200A at idle. And then a battery for the rear close to the amp. You can do a large group 31 or similar, or if space is an issue, you can do a smaller battery. With my 270A hairpin (200A at idle) D3400, and D4700, amp rated for 2600@2ohms where I'm wired, I drop to 13.5-6 on songs with long bass notes. But as far as amp recommendations go, sundown seems to be the more popular choice, or a DC 2k, ampere, etc. The same brands that are recommended on a daily basis pretty much. You didn't say what coil configuration you have, so no clue what resistance you plan to wire it to 1ohm Ok. Well like I said, I think sundown appears to be the top choice lately as far as quality and power go. But look at all of the other brands I listed and that other suggest on this forum, and look to see what voltage they rate their amps at. If you get an amp that's rated 2k@12v, then that will put you a little closer to the 2500RMS mark for your sub. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
RainStryke Posted February 7, 2016 Report Posted February 7, 2016 I picked up one of these during the cyber Monday specials, the dyno birthsheet showed 2099w pretty sweet deal: http://store.soundsolutionsaudio.com/products/twisted-sounds-ts1-8kw-1800w-monoblock-amplifier.html I'd also consider the Ampere Audio 2K with the 10% off right now. Pretty nice deal for $450. http://www.droppinhzcaraudio.com/ampere-audio-aa-2000-1-2000w-rms-monoblock-car-amplifier/
BigHOUSTON Posted February 7, 2016 Author Report Posted February 7, 2016 Looks like im going to go with a FSD 1600.1
RainStryke Posted February 7, 2016 Report Posted February 7, 2016 That amp's guts looks exactly like the Twisted Sounds 1.3K, same bass knob too. Seems like a decent deal for $225.
