super newbish question
rick1024
so im doing setup for my focus with two sa-12 sundown audio subs in a nolte audio double shot and a sae-1500d amp. thi really bothrs me to ask because its such a simple and novice question, but i have had problems with this for a long time.
so, i have 8 gauge for my wiring for the subs, my dumbass question is
how do i get two wires into one terminal?
usually i just trim the wires down till they fit the terminal, but that defeats the purpose of using 8 gauge in the first place. i bought a bunch of banana plugs and was thinking about trying to use those, and my friend told me to use ferulles. problem is i am in germany and for some reason finding hardware and tools is a bit difficult. the ferrule idea sounded good though, if i understand it right you can crimp two 8 gauge wires into a ferrule and still have it be 8 gauge.
anyway, sorry for the most basic thing someone has probably asked
the simple answer is with the power you are running and distance from subs to amp "im guessing that this distance is not more than 5 feet", 8awg is totally over kill.... drop down to 12awg and you will still not lose any audible power output.... unless you find some kind of reducer you cant fit a square peg in a round hole..... worst case is use a wire nut on the 2 8awg wires to a 12awg 3 inch piece and this short run will not lose anything
Agree with motorcity ^^^^
Ur gaining NOTHING using 8ga speaker wire (other than novelty) 14 gauge is just fine for 1500 watt amp, if it makes u feel better u can use 12 ga speaker wire.
  • Who's Online   0 Members, 0 Anonymous, 4776 Guests (See full list)
