Help with speaker DB/Loudness calculator
Andrew Storlie
basicly im hand building a bluetooth speaker and im trying to figure out some math dealing with relative "loudness"
the amp im working with i assume is about 8w-10 per channel left and right. taken from a cheap bluetooth speaker
trying to figure out using math which of 2 speakers would get louder
SPEAKER 1 specs
20rms rated
85.7db 2.83v/1m
80-15k hz
3.5" size
SPEAKER 2
30rms rated
87.5db 2.83v/1m
80-20k hz
4" size but has a phase plug in center
given the same wattage i would assume the 1st speaker would get louder given its a higher % of the rms wattage but then the 2nd speaker has a little bit higher efficiency.... both have same 4mm xmax's and 4ohm loads
  • Who's Online   1 Member, 0 Anonymous, 737 Guests (See full list)
