Box design for Dayton RSS265HF-4
immageek
If you want any help getting WinISD figured out just let me know. There is definitely a learning curve to it.
Yeah I definitely do. I'd love to learn more about it to try and figure some of it out, so that I don't have to bug guys like joe x for a box design. Lol
Well the first thing I would do is get the newest version of WinISD. They don't have a link to it on their webpage, but they did link to it from facebook, here it is: http://www.linearteam.org/download/winisd-07x.exe
The next thing is to make sure you are entering driver parameters correctly. There is a right and wrong way to do it, here is the right way:
1. Enter Mms and Cms
This gives fs. If either is not available, then enter fs and other parameter.
2. Enter Sd, Bl and Re
Now, you should get all but Qms (and Qts), Vas. Please note that Vas may not match exactly what is specified by manufacturer, because exact value of Vas depends on environmental parameters. See FAQ.
3. Enter Rms or Qms.
Either one will do, although I tend to prefer Qms over Rms, because it can usually be measured in driver measurement procedures.
4. Enter Hc, Hg and Pe.
If Hc or Hg or either is available, then enter Xmax and optionally either Hc or Hg if available.
5. Enter number of voicecoils.
This procedure is most accurate. Also note that it also calculates true SPL (1W/1m) value. So it might not match the marketing SPL value, which is generally somewhat vague. Not in all cases, though.
6. Correct Znom, if necessary.
If there are several voicecoils, then you must be careful when entering parameters in that case, because many manufacturers give Bl in voice coils in series, because it yields double value for Bl against parallel connection. If driver manufacturer gives Qes, Bl and Cms or Mms, then you can check how Bl is specified. For that, you can enter following parameters to calculate Re: Qes, Fs, Mms or Cms and Bl. Connection mode can be changed by changing the combobox selection. The driver editor then converts Bl and Re values accordingly.
Equivalently, you can check for Bl by entering:
Qes, Fs, Mms or Cms and Re (for desired connection mode).
If you enter resistance for parallel connection and get about half of advertised Bl, then you know, that Bl was specified that way.
Like in Driver-tab in project window, you'll probably noticed the driver icon in bottom of the driver editor window. you can drag the driver object into some project by just dragging the icon.
Here is a good beginner WinISD tutorial, they are using the older version, so it looks a little different, but all the same stuff is there:
If you have any specific questions, don't be afraid to ask!!!
Builds:
  • Who's Online   1 Member, 0 Anonymous, 433 Guests (See full list)
