16v crescendo 10k or 12k ???
tmacg12345
so originally I was going to get the 12k seeing that it said it ran up to 16v I took that as it could run a 16v system (18volt charging) but then I read that it protects at 16.8-9 volts. if this is true then my 40k rests at 16.7v and that's really sketchy. so I guess my real question is.. is anyone running the 12k @ or around 16v or should I get the 10k and run a unrestricted 16v system?
yes, that is true. a team mate wanted 2 12ks but has 16v electrical, and did serious digging. They talked to the owners as well. He wound up doing 2 10ks, and theyre doing very well.
804B9247-F705-457D-A0CE-347D31C18E35_zps
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
14v(alt) system is 12v batteries.
16v(alt) system is 14v batteries.
18v(alt) system is 16v batteries.
So what you need are 14v batteries and set your alts to 16.7 ish
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
do you know what he's getting out at 16v/18v?
dropping to iirc the high 16s (tested on batt power), he clamped ~21000 with his AMM1. I wanna say 1.2 ohms. Ill ask him all the info if you want. Im drained from the past 3 days.
LMFAO so true
:blush:
  • Who's Online   1 Member, 0 Anonymous, 745 Guests (See full list)
