b00sted4banger Posted April 6, 2016 Report Posted April 6, 2016 Since i dont know shit about port size and length..... Who can/wants/will help me design a box for a single sa-10 running around rms tuned to 35 hertz. Box will be (space limited trunk): H - 12 W - 29 D - 9 Using 1/2 inch wood Thanks in advance
Joe X Posted April 6, 2016 Report Posted April 6, 2016 So here is a suggestion with 5/8" wood, almost your dims, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 1 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
b00sted4banger Posted April 8, 2016 Author Report Posted April 8, 2016 Close is good enough, I have a little wiggle room. THank you!
