Brayden76 Posted April 29, 2016 Report Posted April 29, 2016 Can anybody design me an enclosure for 2 Sundown Sa 12s? I would like a sub up and port in the middle and back design. Ive tried multiple programs and its not working for me. I have about 34w and length and height don't matter. Im looking to run about 2000w at 1 ohm to the pair.
Joe X Posted April 29, 2016 Report Posted April 29, 2016 So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Brayden76 Posted April 29, 2016 Author Report Posted April 29, 2016 Could I use that same box but mount the subs in the top piece?
Joe X Posted April 29, 2016 Report Posted April 29, 2016 Yes, just don't do it if you are installing this in a trunk car.
Brayden76 Posted April 29, 2016 Author Report Posted April 29, 2016 So each front piece needs to be 15.125 inches?
Brayden76 Posted April 29, 2016 Author Report Posted April 29, 2016 And the back port wall looks longer then 11/16
Joe X Posted April 30, 2016 Report Posted April 30, 2016 I have modified a cutsheet to match the figure, sorry.
Brayden76 Posted April 30, 2016 Author Report Posted April 30, 2016 So the inner port wall is only 9/16 long?
Joe X Posted April 30, 2016 Report Posted April 30, 2016 The extensions are very small as you say, being so short you could dismiss them without any significant changes in performance.
