GorillaFIngeRs Posted May 31, 2016 Report Posted May 31, 2016 Fi's subs are very affordable AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
GorillaFIngeRs Posted May 31, 2016 Report Posted May 31, 2016 http://www.ficaraudio.com/product/bl-series-bl15/ AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
Twiztedlemon Posted May 31, 2016 Author Report Posted May 31, 2016 Alright I've set my eyes on the zcon. Is it really a 20~ day turn around to be made?? Anyone know any reasonable and good box builders in the Augusta GA area? Or Atlanta area,as I have a job down there later this month... Or really anywhere in the Southeast region that I can cross reference to see if they fit into my travels.
GorillaFIngeRs Posted May 31, 2016 Report Posted May 31, 2016 I have a crescendo symphony 1500 that I've been dying to put in one of these. The amp did 1800w @ 1ohm on the dyno. Perfect for a fully loaded BL imo. http://store.crescendoaudio.com/symphony-s1500-1/ AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
GorillaFIngeRs Posted May 31, 2016 Report Posted May 31, 2016 AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
Twiztedlemon Posted May 31, 2016 Author Report Posted May 31, 2016 And I hit a nasty wall on my alternator... Had the reply from QualityPower.. "Thanks for the pictures but we cannot provide you with a higher amperage version of that alternator. It is a Mitsubishi alternator and uses a new style stator that no one in the US has a machine to wind. Sorry." Ideas? I don't see a way to mount a second alternator... Per the engine area.
Twiztedlemon Posted May 31, 2016 Author Report Posted May 31, 2016 Shouldn't I be looking at a 2000k amp size to at least almost push it at the nominal rms operating range (2250watt) Although I definitely know I will have an issue with the alternator as I just found out.
Twiztedlemon Posted June 1, 2016 Author Report Posted June 1, 2016 By the way I just wanted to seriously thank everyone for their input, suggestions, ideas, and opinions thus far. I know I'm not the easiest one to recommend to, especially with budget constraints. But just to recap the entirety so far to alleviate all unsure and dead sets. Subwoofer- zcon 15in (most likely, depending on box dimensions, size, and physical limitations) Enclosure : will post dimensions and try my hand at sketchup and some box calculators to find out if I'm correct.... or if someone's amazing and feeling extra generous. (I'm used to sealed enclosures, but will most assuredly go with sub enclosure in a ported to 32-34hz as per recommendations) Amp :still debating- I didn't like the shark I asked earlier, still finding the best fit. Alternators :waiting for some mechanical genius or gods hand in this matter. Side question, with the Zcon vs the HCS soundqubed.... What is the big difference between the two? What justifies the 150$ difference. They both seem to be in the same "weight class" as one could call it, and both have tremendous reviews and ability for recone kits... (And the recone kits... Is that just bad news saying this is going to happen? Or just hey if you fuck up we got your back with a fiscally sound solution?)
RainStryke Posted June 1, 2016 Report Posted June 1, 2016 The Twisted Sounds 1.8K is an excellent board. Mine did 2.2k RMS @ 1OHM on the certified 1%THD test.
