akuma4u Posted June 19, 2016 Report Posted June 19, 2016 hey i used OFC 0 gauge power wire for my amps power and i used plain/chinese brand 0 gauge wire for my ground.. is this ok? or should both ground and power be OFC 0 gauge? thank you
Jessica Posted June 19, 2016 Report Posted June 19, 2016 ground is critical. DC current in a car goes ground ----> positive. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
akuma4u Posted June 19, 2016 Author Report Posted June 19, 2016 ground is critical. DC current in a car goes ground ----> positive. ah... so i need to scrap the chinese 0 gauge and swap it out for true OFC 0g... even if its for 1100rms?
Life is an Enigma Posted June 19, 2016 Report Posted June 19, 2016 If it's not hart stopping it not real POWER
Jessica Posted June 19, 2016 Report Posted June 19, 2016 for 1100? nah, 1100 draws like 120 amps at most. 4ga can handle that. But if you get the chance, go ahead and upgrade to "tinned" OFC wire. it will work better, last longer, not corrode and you will have peace of mind. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
akuma4u Posted June 19, 2016 Author Report Posted June 19, 2016 for 1100? nah, 1100 draws like 120 amps at most. 4ga can handle that. But if you get the chance, go ahead and upgrade to "tinned" OFC wire. it will work better, last longer, not corrode and you will have peace of mind. actually its more like 1350 ,.. but soon to be 2300 when i run it at 1 ohm so i should leave the kicker ofc 0 g power and chinese brand shitty quality 0g ground for now while im running 1300 @ 2 ohms?
Jessica Posted June 19, 2016 Report Posted June 19, 2016 if you are going to upgrade, just get better wire. Go order so KNU tinned OFC. I know it is spendy, but its worth it if you dont like buying extra amplifiers. i was going to post a whole bunch of stuff about how important wire might be. i'll save it unless you want to hear it. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
akuma4u Posted June 19, 2016 Author Report Posted June 19, 2016 if you are going to upgrade, just get better wire. Go order so KNU tinned OFC. I know it is spendy, but its worth it if you dont like buying extra amplifiers. i was going to post a whole bunch of stuff about how important wire might be. i'll save it unless you want to hear it. go ahead and post it.. no harm in getting better educated ill be honest,.. all the guys in the shops told me that good brand/quality OFC 0g is good enough and will do the job.. this is the first time ive heard of tinned ofc..
Jessica Posted June 19, 2016 Report Posted June 19, 2016 Tinned OFC will prevent corrosion, which will eliminate heat, bad connections and wire that just falls apart after long term use. as for the rest: 0ga cca can handle about 200 amps on shorter runs and you probably will never see that on music. I have seen so many builds draw only half what the amp could draw on music. Think about an amp, it outputs AC power, so its a sine wave, so it sweeps up and down through a peak to peak. Most the time the amp is in between peaks. So the draw on the DC side is not going to be really high. Sometimes it is a high draw though, and that is when you might run into issues. If you play a lot of music that happens to be where you have very little impedance rise you might draw quite a bit of current. Amps have internal power supplies and they have capacitors that even out power, they dont really "store" power, they just help flatten out the high and low draw cycles. The kind of filter the power coming in and regulate it. Anyway, at the end of the day, you are just taking an AC input, boosting it on the input side of the amp, sending it to the real amplifier and increasing the voltage. Like i said, its a sine wave. notice how house wring can run 115 volts and 15 amp, which is about 1725 VA? (Watts, sort of) EDIT: on 12ga wire You cant do that in DC cause its constant and not alternating. That is why you tend to need a lot more copper to power DC things than you do AC things. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
hdorre Posted June 19, 2016 Report Posted June 19, 2016 If i were going to skimp on anything, itd be my power run. I like muh return path. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
