Subs cut out randomly
My subs cut out on the way to work the last couple days. I've got 2 Fi BL 12s and a Rockford 1500bdcp. They've been installed and fine for a couple years now the only thing I've done different is took the stock grounds out from u Dee the hood so I could pass the engine ground through the battery current sensor. They'll cut out for a couple seconds then turn back on. What can I do to troubleshoot the problem?
since u recently messed with the ground that is your problem.
maybe not tightened enough see if you can move it with your body weight
give your terminal a good tuggy
I remember you posting about doing a run through the current sensor. Are you seeing spikes in voltage?
If your voltage is bouncing high, that will cause the RF to go into high volt protect.
I'll pay attention to that on the way home. Do you think it could be because I only have the engine ground going through the sensor? If I connect the chassis ground to the engine ground at the alt bracket would that be the same as splicing it into the middle of the engine ground before the sensor?
test the subs with a DMM and visually check them as well. also what is your gain set to? where is your amp grounded?[/quote
I set my gain with a dd1 my amp is grounded to the bolt that holds my trunk latch.
The ground is tight in the trunk I messed with the grounds in my big 3. I removed stock grounds so I could pass the 1awg through my current sensor but both the stock grounds ran through the sensor before I took them out.
bolt holding your trunk latch is a horrible spot. change to the floor pan and that will be tons better. use your own screws as well.
I'll do that but I have a feeling that's not my problem
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
