ThePilot Posted July 13, 2016 Report Posted July 13, 2016 Forgive me..this is probably gonna be a stupid question..I have a single 12 mounted on top of the box with port facing rear of trunk..the sub itself is mounted on the left side,not in the middle,and it's directly under the left side deck speaker (6x9) with about 2-3 " clearance .there's no other orientation possible.my question is this: will the magnet hurt the sub or the sub kill the 6x9 above it? I know some peeps would just delete the rear speakers all together,just running good power components up front,but I'm used to rear fill..I'm not running much power,will it be ok? Jojo Pelletier / South Alabama
3vil Posted July 13, 2016 Report Posted July 13, 2016 Can the subwoofer physically contact the rear speaker? If not then you're OK.
ThePilot Posted July 13, 2016 Author Report Posted July 13, 2016 Doesn't touch,although at full excursion it comes close,but never actually touches.. Jojo Pelletier / South Alabama
Triticum Agricolam Posted July 13, 2016 Report Posted July 13, 2016 You are fine then. Building a new box so the port and sub are on the same side and then facing them both back may improve performance though. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ThePilot Posted July 13, 2016 Author Report Posted July 13, 2016 Yeah,the original plans,drawn up by JoeX,had the sub same side as the port (facing back)..I used the cut sheet from those plans but I'm guessing the plans were intended for a 10..I already had almost a full sheet of 3/4 mdf from a previous build so I went with it,not realizing the sub wouldn't fit the front face til it was time to cut out the sub. I guess I'll start over....ty for the replies Jojo Pelletier / South Alabama
