Some Questions
XflAQ
The more you explain, the less sound quality oriented and more ... mids and highs to keep up with my bass.
... but I want a clean and clear sound ...
Hard to get. Well, so it seems.
I looking up your vehicle to see what you are working with.
From what I'm reading ... you will need ALOT of amplifier power.
Sorry for the misunderstanding but I desire my mids and highs to over power my bass as I know my bass will have no problem. However, I don't want my bass to drown out the other frequencies. With that said, overall, I would like to have clean and crisp sound.
Why would I need "A LOT" of amplifier power?
First off brother (and not meaning this bad to anyone on this forum) ... the term "mids and highs" is spl ground pounder oriented. Not custom auto sound. You have a broad spectrum that needs to be filled to complete your goals. So we need to be a little bit more specific to help you get what you want out of your system.
You need more power for dynamics to blend with massive sub bass. I average about 150 wpc on every driver on my front stage setup.
... and I only had to blend with 4 10s isobaric.
My apologies. My goal is for a quality blend between my mids/highs with my lows while my mids/highs are still heard loud and clear. So I suppose I am after SPL rather than SQ, though I do not want even the slightest below "great SQ." I should ask this in the Mids/Highs section instead but since I have this opened up with you I may as well ask here.
My HDS315s are 1200WRMS each and I'll be wiring them 1-ohm to my amp that produces 2300x1 @1ohm. Would I be ok to choose four mids that run ~100WRMS ea and two tweeters that run ~60-100WRMS ea? As in would those blend/still be heard over my lows and not be drowned? Would four 6.5" mids be fine or would I need to have a couple 10" too, or does that depends?
As for the Pioneer DEH-80prs HU, what do I do with the crossovers? Like I know how to set them but do I leave them alone on my HU and only use the crossover @amps or do I use the HU? Do I match?
Sorry for the run around and questions lad, I just want to have an understanding of what I specifically need to look for.
  • Who's Online   0 Members, 0 Anonymous, 1794 Guests (See full list)
