GoldSilverEagle Posted July 27, 2016 Report Posted July 27, 2016 Hello. I'm a new member. I have 2 sundown audio x10 v.2 D4 Rev 2 with a sundown audio scv-3000d amp. I built my enclosure to their online recommended spec, but feel that if each speaker was independent from each other it would be more beneficial. So I'm wondering if I make a new enclosure and put the ports on either side of the box and double wall the center. Would that work better, or at least equal? And with the ports to the outside, can I still use their enclosure specs and just cut down middle and flip the 2 halves around? . Thank you in advance for your time and input.
Nightshade Posted July 27, 2016 Report Posted July 27, 2016 A common chamber, common port will do better for SPL. What you are suggesting, if each side is identical, should do better for sound quality. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
