I have a american bass ph4000md, wired at 1.33 ohms before any type of ohm rise. At full volume i drop down to 12.10 volts, normally i''m resting around 13.8-13.9 the stock alternator is around 130 amps i believe if i were to get a 240 amp alt would it be worth the price (around $400)to give the amp that stable voltage. Would i even see an increase in db or power?
The alt should make a noticeable difference. You should also do the big 3 and maybe even add a battery to the trunk.
Pioneer 80PRS
I have the big 1?, Upgraded the battery ground! the sky high car audio 0 gauge lug wont fit on with the stock wire not enough threads left on the bolt to get the nut on with both wires! (this is on the positive on the alt)
and for the last frame to engine ground i will
be doing that soon. Adding a second battery in the rear sounds like a good idea. i'll take that into consideration.
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
