Bandpass vent tuning
Black24s
So I am getting a little frustrated trying to figure out my vent length for my 4th order bandpass for 2 XFL 1522.I have am working with about 15 cubes total and 175 Sq inches for the vent opening but can't not figure the vent depth. I am hoping to tune to about 50 - 55 if possible. I have tried every link or calculator I could find so I figured someone in the forums could help. Thanks
What do you mean you tried calculators? What did you do with them that didnt work?
Clarion cz702
Ssa evil mids and tweeters
ppi 900.4
2 zcon 18s
Taramps 10k
3 big dekas 1 xs
3 runs of 4/0 and big 3
300+ amp ohio generator
155.7 on dash at 36 (peak) 152 at 25
figuring the ported aide of a 4th should be just like figuring a normal ported, just exclude the sealed side when you design it. Note that it can be tricky to get a huge port and a high ratio design to work well if you do not have the space;
as far as modeling software, cant help. not like it will matter as it all changes in the car anyway.
You can find yourself in a situation where your combination of ported volume and port area will not allow you to tune above a certain frequency. This is probably where you are at. To tune higher you need to either increase your port area or decrease your ported volume.
Builds:
I just went with the wing it method and made a couple different vents that were interchangeable until I found what I was looking for. I ended up using 18.75 x 16.5 x 6.8 deep.
  • Who's Online   0 Members, 1 Anonymous, 4914 Guests (See full list)
