I have had this issue pop up in several cars I have had systems in, but have always been able to figure out this issue rather quickly. This time its different , I can not come up with a conclusion to get rid of this whine I have through the interior speakers. I thought it might have been my older rca cables, so I ordered a set of SMD rca's. once installed the noise completely went away. My wife went to the store later that day and came back with the noise I though was gone. Since then I have not been able to get rid of it. I also tried installing my wife's head unit in my car that has no whine in her car, of course it whines in my car. I know its not the head unit. Any ideas on this one would be greatly appropriated.
Would a alternator going bad cause this issue. Going off the gauges, seems like its working well, as in functioning.
List of what I have, or done if it helps.
2005 Ford Escape
-SMD rca's, ran down the middle of the suv
-Pioneer AVIC-8100NEX/XNUC
-Pioneer ND-BC8 rear camera
-Rockford Fosgate T400-4
-XM sat receiver
-Sundown SCV-2000D
-Sundown 1) X12 V.2 D2
-SMD fuse block
-SMD power and ground block
-stock alt
-SMD battery indicator
-SMD fan thermostat
-Yellow top optima battery
-0 gauge power and grounds
-battery ground to chassis
-ground from engine to chassis
-power wire from alt to battery
-using the ground from the rear of car, where the amps are grounded,also tried alt locations with no sucess
-tried disconnecting anything extra, such as engine ground, alt power, xm radio, battery meter, fan thermostat,, phone charge, radar detector, nothing helps.
-installed a second head unit only to have the same issue
-grounded the rca's, makes worse
-tried a ground loop isolator, makes worse
Check the ground on your radio harness. It's happened to me, where it just got a little loose causing that noise and every way I tried didn't work. I ended up sticking some 22 gauge wire in the spot where the radio ground was. Don't take the wire out
Try grounding hu to battery. Sometimes they have a crappy ground.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
