Help with new system
Hi,
I have this 1996 Corolla with a 160amp alternator, a SCV 2000d, and 2 Sa12 d4's in a ported box
I was wondering what my options are as far as powering/wiring?
I also have a sony 4 channel amp that i might put in for the door speakers, its something like 300 rms but honestly i dont know if i want to do the extra wiring.
I have no other electronics in this car, its a base model. Can I get away with just like a yellow top in front?
Thank you, all criticism welcome.
Well the way I see you really have 3 options.
  • 1. Buy good quality wire that is larger than you need, thus allowing you to easily upgrade amps down the road
  • 2. Get shitty cheapo wire, probably CCA and too small for that amp, then run it and wonder why things aren't working correctly
  • 3. Put the amp and subs in your closet and don't worry installing them
For wire, i was looking at knukonceptz kolassus 1/0 gauge. Im guessing this stuff is legit? or should i look into Rockford fosgate?
But as far as batter(ies) would i be good with getting something like a yellowtop in front? I dont really understand how much this amp is going to need. I rather not add an extra battery or a massive battery if i dont have to. Too much extra weight for the 1.6L 3 sp auto hahahaha
O would upgrade Underhood battery to biggest xs power battery that will fit. Do big 4 all in 1/0 off shca. Buy a decent voltmeter and run it to the scv2000d and watch voltage. Our u going to eventually upgrade or no?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
So you recommend shca wire?
I dont plan on any other upgrades besides maybe the little 4 channel amp for the door speakers. I think what i got already might have been overkill hahaha
another quick question though, what gauge wire is meant for SCV2000d speaker output?
Okay, so it looks like I could drop in a d3400, would this be enough? Or should I look at another battery?
From what i measured, I have
L= 9in but it can go to 10in
W= 7in but it could go to 71/2in
H= 8in I might be able to squeeze another 1/4 in
Okay, so far I've got a 50ft spool 1/0 ofc from shca, a d3400, bunch of crimp ends, etc.. We'll see how this goes. You guys think the d3400 and 160 amp alt will keep up with the scv2000d and a 4 channel amp?
I would hook it all up and watch your voltage. But would recommend a battery in the back. Like a d3100 or xp3000 never have enough electrical
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
