Shanerator Posted August 20, 2016 Report Share Posted August 20, 2016 Hello, I have 2 Crunch 2-channel 500w amplifiers.. Specs are: 4 ohm stereo 2x 70w, bridged mono 250w rms, 2 ohm stereo 2x 125w rms. I am using one for powering 220w rms sub and one for front speakers... They are 50w rms, 350w peak blaupunkt pair.. So the point of my topic: If i buy another set of these speakers and put them in parallel with the fronts. Please confirm my questions or deny them: 1.) Because all speakers in that way are the same (all have 4 ohms) i can run them 2 on each channel and in that way make 2 ohm load, which is ok, because my amp is 2 ohm stable. 2.) i will then have 62,5 watts per speaker? (2 on each 125w channel), which is also ok, because its slighty more that speakers rms (50). 3. its worth it, because its like a free power for a new pair of speakers. Tnx.. Link to comment Share on other sites More sharing options...
SkarredSierra Posted August 20, 2016 Report Share Posted August 20, 2016 1. Yes 2. Yes you should be fine with gains properly set assuming the amp puts out its rated. 3. Are these going in a front stage or rear fill? Also here is a site to help wire you speakers correctly http://www.the12volt.com Link to comment Share on other sites More sharing options...
Shanerator Posted August 20, 2016 Author Report Share Posted August 20, 2016 thanks for the reply and a link.. I will use them for a rear fill.. so.. the same gain, filter, etc.. for all 4 of them (obviously)... Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 20, 2016 Report Share Posted August 20, 2016 The only downside is that you won't be able to fade front to rear. This will make the rear too loud and will tend to drag the sound stage image behind you. It will be louder if that's all you are looking for. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
