zanekeimigdesigns Posted August 23, 2016 Report Posted August 23, 2016 In order to use time alignment in its entirety you have to have woofer, midbass, and tweeter all off different amps and channels off of the sound processor itself correct? Reason im asking is if i run a component set and want to change the time alignment it is going to change both the midbass and the tweeter. Is time alignmemt really important on tweeters?
3vil Posted August 24, 2016 Report Posted August 24, 2016 TA is important for SQ anytime you have two or more speakers that are not right next to each other. And to answer the earlier question, yes you would need one speaker per amp channel to "properly" align things.
