robertdbardos Posted August 24, 2016 Report Posted August 24, 2016 I have done some research and can't manage to find a box that I can use. I have tried to match the sundown specifications of 32 Hz and 60in port area. I would prefer aero port but I don't mind if its slot. In doing a trunk wall 38 wide 16 tall 18 deep would be awesome so I don't have to make a two part box. My goal is to move air lots of air but maintain being musical. Every time I get close to specs I'm way off on Hz or port area. Frustrating. I will have it on a b2 zero.5 amp any help would be appreciated.
ckeeler11 Posted August 24, 2016 Report Posted August 24, 2016 You dont have enough room. you can get it with a depth of 24.5" and a slot port at 14.5x5"x36". That's with double baffle and some bracing.
robertdbardos Posted August 24, 2016 Author Report Posted August 24, 2016 Ill see if I can fit it thanks!
fyerbyrd22 Posted August 24, 2016 Report Posted August 24, 2016 it would be TIGHT, but u could do a 6.25 or 6.5" aero, about 12" long and get pretty damn close to 4cu+ and 34hz, with adequate port area...imo, not ideal but given your space, might be your best option personal build in progress http://www.stevemeadedesigns.com/board/topic/188656-2013-kia-sorento-6-12-no-wall/ www.facebook.com/TurbulentDesigns
robertdbardos Posted August 24, 2016 Author Report Posted August 24, 2016 With the same dimensions as i posted? I can fit a bigger box but would mean I would have to build the box inside the car
