islandpride684 Posted August 25, 2016 Report Share Posted August 25, 2016 Ok so I'm out here and it is making noise with the engine off and stereo on, a hum noise and if I shut door or anything it makes noises Shoot a video real quick of what it sounds like, also just cut the black (ground) wire from harness, connect a ring terminal at the end (connect to wire coming from headunit) and find a good metal contact behind the headunit and ground it there...is there noise when the rcas are unplugged from the amp? Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
welderblake21 Posted August 25, 2016 Author Report Share Posted August 25, 2016 It makes no noise if unplugged from the amp. Ground to amp is good, all connections to amp are good. Seems like the rcas are the problem but idk how they could be they worked fine not long ago. Link to comment Share on other sites More sharing options...
welderblake21 Posted August 25, 2016 Author Report Share Posted August 25, 2016 Ok just hooked up brand new rcas and same thing Link to comment Share on other sites More sharing options...
welderblake21 Posted August 25, 2016 Author Report Share Posted August 25, 2016 How do I post a video. It's doing it now with out rhe rcas hooked to the amp Link to comment Share on other sites More sharing options...
welderblake21 Posted August 25, 2016 Author Report Share Posted August 25, 2016 Im just gonna trash this amp and try a sonido mask fx3000. I think somethings wrong with this amp Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 26, 2016 Report Share Posted August 26, 2016 Ok lets go back to the beginning. In post #8 you unhooked the rcas from the amp and the problem stopped. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 26, 2016 Report Share Posted August 26, 2016 Turn your gain all the way down and lets do this one step at a time. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 26, 2016 Report Share Posted August 26, 2016 Turn your engine on with amp on and the rcas unplugged from the amp. Any noise? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
welderblake21 Posted August 26, 2016 Author Report Share Posted August 26, 2016 If I unhook the rcas from the amp it still has engine noise but it's not as bad. I think it's the amp, because I've not had this problem until I put this amp in Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 26, 2016 Report Share Posted August 26, 2016 Is the gain turned all the way down? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
