PinkFreud65 Posted September 14, 2016 Report Posted September 14, 2016 Ok. keeping this simple. Buddy has a single L7 12 in a prefab box. He wants me to make him a box. He has a 2014 Camaro. I want to build a (as small as I can build) ported enclosure for him. Maybe tuned to 35hz? Whatever honestly. He wants it small, and I want it to sound decent. So, just shoot me some designs if you wouldn't mind. Thanks!
Joe X Posted September 14, 2016 Report Posted September 14, 2016 You need to post max dimensions for a box that will fit through the trunk opening which is not too big.
PinkFreud65 Posted September 14, 2016 Author Report Posted September 14, 2016 You need to post max dimensions for a box that will fit through the trunk opening which is not too big. Trunk opening is 33"w X 16"h let me know if you need any more measurements!
Joe X Posted September 14, 2016 Report Posted September 14, 2016 So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 7/8", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
PinkFreud65 Posted September 14, 2016 Author Report Posted September 14, 2016 Joe, thank you so much! I will put together a cardboard box to make sure it will work. I will let you know if we are good or if we can change anything up.
