gabe Posted September 20, 2016 Report Share Posted September 20, 2016 how accurate is clamping to find wattage? curious because i used a dd1 and multi meter to tune my t-1000bd just didnt distort till 56v but i set it to 52volts cause i got 2 12 jlw7s which is technically 1800watts (52*52)/1.5=1800watts but not for sure its getting 1800watts it bumps but i wana be for sure that why im asking if clamp testing is accurate or some what in same range maybe off by like 100 watts or something Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 20, 2016 Report Share Posted September 20, 2016 I would run two runs from the back battery to the amp. I would keep the single run front tot back to begin with and keep an eye on the voltage. Then I would add a second run front to back to see if there is a difference. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
