Amp Test Tuesday - AudioControl Epicenter 1200 - Rated 1200w RMS 1 ohm (AD-1 Amp Dyno Results!)
(Partial repost from the Amp Guts section)
You may have seen this amp on my test bench for at least a month. I used it for a few things (other than testing ie. woofer flex vids etc) but have not had a chance to actually test it on the AD-1 Amp Dyno
We all (should) know that Audiocontrol is a quality company all the way. Always has been, hopefully always will be. Below are some specs and then some nekkid' pics of it! Amp guts :D It was a lot of screws and i almost didn't crack it. But i bucked up and did it. Only had 3 left over when i put it back together. I think that's a record! Now i have spares! :D (JK of course).
Click here for previous "Amp Guts" pictures - http://www.stevemeadedesigns.com/board/topic/206804-audio-control-epicenter-12001-amp-guts-pre-amp-test-tuesday-pics/
The Epicenter® 1200
high-power subwoofer amplifier:
When car audio systems demand high levels of subwoofer power output into difficult loads, and a wide range of adjustment to optimize the subwoofer performance within the system, the AudioControl EPICENTER® 600 and 1200 power amplifiers are the ideal solutions. Each model delivers high current, stable down to 1 Ohm, and each has a removable top cover that allows access to controls for THE EPICENTER® effect, crossover frequency, gain, polarity, subsonic filter, signal sense and expansion bus mode.
features
High Current Design 1 Ohm Stable
1200 watts at 1 Ohm
THE EPICENTER® Digital Bass Restoration
MILC Maximum Input Level Control (Patent Pending)
24 dB/octave Linkwitz-Riley Alignment Crossover
GTO Signal Sense
PFM Subsonic Filter
Line-Level RCA Inputs and Active Speaker-Level Inputs
Solid One-Piece Aluminum Chassis
Remote Control for Subwoofer Level and THE EPICENTER® effect
Expansion Bus
  • Like (+1 Rep) 2
Follow my Tweet (Twitter)
