killerc998 Posted October 13, 2016 Report Posted October 13, 2016 ok I'm just trying to see what some of yall recommend. I will be running 4 ct-sounds strato 8s dual 2 ohm. they will be wired down to 1ohm. the amp is a ct-sounds T1500.D1, 1500 rms 3k max. The box will be roughly 4 cubs need to finish designing/adding braces. I will be building a box similar like the pic. I will be doing it this way so I can get a port long enough. This will all be going in a single cab s10 with a blow through. The subs specs if needed are Fs. 48.04HzQts 0.508Vas 7.05 Qes 0.57Qms 4.42Spl 83.2X-max 12.5mmCoil size 2"Power website 400rms/800max (spec sheet 300Rms/600Max) Now the web site show 450Rms/900Max Don't think they can make up their minds. Gonna have to call them on this one. Thanks in advance.Chris
ckeeler11 Posted October 13, 2016 Report Posted October 13, 2016 What type of music will you be playing? you looking to get as loud as possible (peaky) or play flat?
killerc998 Posted October 13, 2016 Author Report Posted October 13, 2016 play a lil bit of all, but mostly country, rock, and old rap
