Single 10 inch subwoofer box help?
Matt head
I have a 10 inch kicker compS I would like to build a ported box for. I have the specs for the sub and was curious how compact I could go and keep a good sound.
Specs:
10 in kicker compS
4ohm
600 watt max
300 watt rms
1.25 cu. Ft. Min
1.75 cu. Ft. Max
4.8125 mounting depth
9.125 cutout
It is going in the trunk of a 2008 chevy impala but I would like to keep it on the smaller side. Any photos or designs you have laying around would be greatly appreciated.
So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 1 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 6288 Guests (See full list)
