Sub woofers being off set from blow through hole. (starts 4th post)
killerc998
How bad is it to have a port ratio of 10. the port would be 3*x30, which comes to 90 square inch of port. I will be round the edges of the port. I know its not ideal. I would rather do 4x22.5 but don't have the room. Its in a blow through. The hole is 11.5 tall x 39.5 wideand the subs take 8.5" outside mounting depth. it leaves me just 3". trying to see what yall think.
Subs are ct-sounds strato 8s dual 1ohm, running it on a t1500.d1 (3k max) box is almost 6 cubes before displacement, and will be 4 cubes after subs, port, bracing.
electrical is upgraded for stock 105 alt to an ad244 145 alt, 2 super start platinum agm 78plt batteries (its what I have local and I don't want to ship batteries for any reason), running 1/0 ofc military spec wire, only place I have cca wire is the 1 ft run from the power shunt to the t1500.d1, ran out of the other wire.
At 10:1 you are quite a bit over what I'd like to see. Based on a equivalent area formula I use your 3" x 30" port will be roughly equivalent to a 9" round port, or 64 sq in. You may want to increase the port area some to compensate if you can.
Builds:
would setting the subs off set from the blow through cause any problems? I'm trying to find a way to get more port square". I have looked and all I can find is a youtube.com video. https://www.youtube.com/watch?v=Y9WCYG1goDQ subs are shown from 0:04-0:11. Please let me know if this will cause any issues. And will it cause a loss of sound?
  • Who's Online   0 Members, 0 Anonymous, 4839 Guests (See full list)
