Highest Wattage Burst Per Sub
Well Alan Dante is doing 2 18" DD 9918Z's and hopeing to do over a 183db. Cant rememeber how many watts he said hes looking to do.
Already done with 2 15's. I talked to him a few days ago.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
Hes running 2 15"s now not 2 18"s? Or he did the 183+ with the 2 15"s and still going to be louder when he does the 2 18"s?
So any regular good sub (L5 12) can take at least 4000 watts in a "daily" set up, at least bursts
And many more can take much, much more...so far upwards of what, 40,000 watts repeatedly...even many times and still survive
IB3 22"
Why does Kicker rate the SOLOX so much different than most subs? I see a lot of daily driver solo18's being run of just 1 2500.1, and the Kicker suggestions are:
vented compact 5000 watts peak
vented suv 4500 watts peak
sealed compact 2800 peak
sealed sq 2400 peak
which makes sense, till you get to the "SPL" 10,000. Any "SPL sub" takes high wattage, and in any SPL alignment it completely depends on setup.
If a 12" L5 can take 4000 watt bursts in a daily setup, plenty more in an "spl alignment", why rate the soloX at some random number?
IB3 22"
Extreme car, will HOLD the frontal pressure.
Now if your talking a 'normal' daily driver, 4000 on L5 12"
rated 1200 watts peak, but will take 4000 normal, more if Extreme
you used to run a 12L7 off a kx2500.1 2 years ago, right?
IB3 22"
No he is keeping the 2 15's because there "built better" then the 18's he had.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
  • Who's Online   0 Members, 0 Anonymous, 3024 Guests (See full list)
