Box Design: I need a 7 Cu. Ft. Box... But I can't get the tuning.
whazoo84
Ok i have another go in 5 also what amp you running it on
What amp are you running?
if you are doing a slot port on torres then you enter the height, width, and length. if doing an aero then you do the number of ports, diameter, and length you dont do both sections. Also need to put 3 for common port walls if port is going to be top to bottom of box and turn in an "L" shape.
Since I'm no longer running 3 of these I'm gonna run these on a SoundStream T6000.1D and for the doors a X3.2K4
Right i came up with this from the new dimensions. http://imgur.com/a/Yg3gJ
Looks good!
you are using torres wrong. use either the fields for square port OR slot port, dont use both.
Didn't know, good to know!
  • Who's Online   0 Members, 0 Anonymous, 1576 Guests (See full list)
