GorillaFIngeRs Posted January 2, 2017 Author Report Posted January 2, 2017 I'm open to suggestions for sure, i don't have any experience with a sub like this. I was aiming for 32hz @2.5 cuft which is biggest recommended according to specs. I really just want it to sound super clean and get the lows nicely, which is why I want to use aero ports . I will be running it with a crescendo s1500.1 for now. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
GorillaFIngeRs Posted January 3, 2017 Author Report Posted January 3, 2017 Achieving the desired port area seems a little trickier than I originally anticipated. It seems like I will have to have a bend or an external port to achieve the tuning I want. Can someone please point me in the right direction. If I did have a bend internal to the box where could I get the 90 to make the turn? Thanks again AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
GorillaFIngeRs Posted January 4, 2017 Author Report Posted January 4, 2017 On 1/1/2017 at 2:05 PM, Triticum Agricolam said: Sometimes, sometimes it is not though, which is the problem with rules of thumb. Given the space you have to work with and the amount of power you are going to be running, with a 2.5 cu ft box a slot port of 40-50 sq in would be good. What about an aero port? I was thinking of going that route so I can easily change the tuning. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
