Need Enclosure Help For build this weekend!!!
GorillaFIngeRs
I'm hoping to start a build this weekend for a FI BL12v3. I am not having any luck downloading torres box calc so I was hoping to get some help from some of you audioheadz. The box I currently have is 20dx15.5hx30w, FI recommends a 2.5 cu ft enclosure max so I believe I will be able to have a smaller box. I want to go with an aero port on this as well to try something new. I will be pushing the sub with my Crescendo s1500.1 @ 1 ohm so around 1500w. Any input is appreciated, thanks ahead of time.
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
What kind of music do you listen to or what frequency do you want to tune to?
Pioneer 80PRS
Mostly rap/hip hop. I was thinking 32hzish or whatever someone recommended for that sub.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Bump.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
How do you calculate how much port area is needed for a sub? The specs don't come right out and say it. I can design this if someone can help me figure out how much port area I am looking to achieve.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
It depends on how much net volume the box will have, what frequency you are tuning to, and how much power you are going to be running.
Builds:
3 hours ago, neuspeedescort said:
14 to 16 sq.in per cu.ft is a good rule of thumb when doing a slot port.
Sometimes, sometimes it is not though, which is the problem with rules of thumb.
Given the space you have to work with and the amount of power you are going to be running, with a 2.5 cu ft box a slot port of 40-50 sq in would be good.
Builds:
2 hours ago, Kyblack76 said:
Hate this suggestion.
For the love of God, please let the per cube "rule: go the fuck away. Please.
thanks for the constructive input......
yeah rules of thumb like Triticum Agricolem stated are not always enough.  but they do make a good starting point.  i have built enclosures with 18-19 per cube.
  • Who's Online   0 Members, 0 Anonymous, 930 Guests (See full list)
