Michael Dean Posted January 6, 2017 Report Share Posted January 6, 2017 DB drive a7 2000.1 1Ohm Stable Class D Monoblock Subwoofer Amplifier RMS 740x1 @4 rms 2200x1 @1 Working Voltage 8.5-16 Volts Frequency Response 20 hz-250hz Signal to Noise Ratio <100db Damping Factor 250< Low Level Input 6v-0.2V Low Pass Filter 35hz-250hz ( @ 24dB Slope ) Bass Boost @ 45Hz 0-9db Subsonic Filter ( @ 24dB slope ) 10hz-50hz Phase Shift Master/slave ( Linkable ) yes Remte Level Control yes RCA line Output yes Minimum working impedance 1ohm Skar rp2000.1 4 Way Protection Circuitry : Thermal, Voltage, Speaker, DC RMS Power @ 4 Ohms : 800 Watts x 1 Channel (14.4v) RMS Power @ 2 Ohm : 1,400 Watts x 1 Channel (14.4v) RMS Power @ 1 Ohms : 2,000 Watts x 1 Channel (14.4v) MOSFET Power Supply Soft Turn on Circuit Frequency Response : 20Hz~250Hz Signal to Noise Ratio : 85dB Damping Factor : 150< Low Pass Filter (Variable) : 50Hz~220hz Subsonic Filter : Off~50Hz Remote Bass Knob & Wire Included 1/0 Gauge Power and Ground Terminals Working Voltage : 8.5V-14.4V Fuse Rating : 200 Amp Dimensions : 17" (Length) x 6.3" (Width) x 2.2" (Height) According to these specification what amp would be of better quality? Link to comment Share on other sites More sharing options...
Jessica Posted January 6, 2017 Report Share Posted January 6, 2017 im pretty sure superman would beat batman Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Michael Dean Posted January 6, 2017 Author Report Share Posted January 6, 2017 1 hour ago, strangeduck said: im pretty sure superman would beat batman And who is Superman???? Link to comment Share on other sites More sharing options...
