Can you help me understand.....
FantasticBass
So I attached a PDF of the Transfer Function Magnitude from WinISD Pro for the box I'm designing for my two Sundown Audio SA-15D4's.
So I know that a lot of people will use this program to see how the box will "sound". So by looking at this graph, how do I know how it will sound?
And in explaining the theory of it to me, how will this design actually do with my two SA-15's? What I can understand from the graph is that it will be a low end monster. Again no clue what I'm truly looking at so, just guessing really off of what information I've found through researching on the internet via google.
So what am I looking at basically? Does F0.5 at 30hz mean it's going to be louder than say if it was at F-3? Also on this box 55.81hz is something crazy like F6.5, so what does that mean?
transferfunctionmagnitude for two sa-15 @ 1500w.pdf
It looks like peak output will be between 50hz and 55hz. The lowest frequency usable output is considered to be the 3db down point and appears to be around 35hz. Will it play lower? Sure but won't do so loudly and at the risk of unloading the sub. What are the specs of the box and port?
Pioneer 80PRS
ShadeTreeMechanic, Box is 9.18 cu ft after all displacement with two SA 15" DVC 2 ohms with the SAE1500 wired to 1 ohm to deliver the full 750 watts rms per sub. I'm using 2 6" aeroports at 13.5" long for a final tuning of 29.89hz. Now from what I read though F -3 (negative three) is the cut off point where it won't play loudly and run the risk of unloading. and that's at 23hz on this graph. At 35hz I'm actually close to F1.5, so is it F0 where you won't hear the bass anymore and the sub will unload?
Everything relative, when one sound is 3db down from another it would only be half as loud. The peak being so much louder than everything else means that this would be the highest output. Sure it will play the lows, it will just play the upper bass louder.  Two 6" ports sounds small for two 15s. I don't know your subs that well, but maybe someone else will chime in.
Pioneer 80PRS
They're not beastly subs lol. They're nice though. I'm only at 8% port velocity at 23hz, which I won't be playing anyways by 30 hz i've dropped down to 6.5% port velocity. I know you want 5% port velocity but I've plugged in box recommendations from manufacturer box designs and they've been upwards of 10-15% in the port velocity print out
  • Who's Online   0 Members, 0 Anonymous, 1962 Guests (See full list)
