Hooah87 Posted January 21, 2017 Report Share Posted January 21, 2017 Does anyone know of a 4 channel amplifer that does about 100x 4 at 2 ohms, has front rear and pass thru low level input and output, but most importantly has the ability to sense the front input and use it for the rear rca input, so if you only have one set coming from head unit. And then be able to use the pass thru output to run to my subwoofer amp. Hope I'm not too confusing. Thanks for the help Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 21, 2017 Report Share Posted January 21, 2017 De javu 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
