Posted Image
  Posted Image
  Posted Image
  Posted Image
Posted Image
Follow my Tweet (Twitter)
more updates.......spinners off the 26's, brakes are all done.  Its hard to see the brakes on camera i might have to wait till daylight and see if i can get a good angle.
  Posted Image
  Posted Image
  Posted Image
The 26's are so big they dwarf the rotors but those are every bit of 15"  :eek:  I know people still rolling of 15" rims  :D
  Posted Image
I think it looks good with the spinners although im not into those anymore.......but they were still 26" spinners which is kinda pimp no matter how you look at it.  I do think they look sweet without them as well.  Its really up to him if he wants to keep them on or not.....so far the vote in the hood is leave em off  :)
anyway, it was nice out so i thought id post some pics of what this thing looks like full view outside the garage.  Hasnt been any of those since like the very first pics. I like how you can totally tell its got a new interior even from kinda far away.  Plus, i dont think i posted any pics of the new Billet Grill we installed a while back.  Anyway Here they are..
  Posted Image
  Posted Image
  Posted Image
  Posted Image
  Posted Image
  Posted Image
got some more stuff done this last week with the wiring (after work-work) then put in some hours this weekend making a trim piece for the back.  Got more stuff to do to the top (gotta trim it all out)
Everything in the back is eventually getting wrapped in suede just like the interior.
  Posted Image
that was before ^^^^
now i took a saw and cut 1/4" grooves just wide enough to run wire thru so it is all flush.  Wires all neat now and ready to be hidden under a trim piece (later)  There is 3 LED's (red, blue, green) each has its own wires....so there is 3 sets running thru each groove.
  Posted Image
  Posted Image
  Posted Image
  Posted Image
  Posted Image
Time to seal the box off once and for all......added (2) 1/2" strips of weatherstripping all the way around
  Posted Image
doubled up on the screws since a few "spun out" after being put on/taken off too many times.  No worries, now its even tighter.
  Posted Image
time to start framing it out.......freestyle baby  :)
  Posted Image
  Posted Image
  Posted Image
Posted Image
Posted Image
Posted Image
just to make sure she is nice and strong i added  a layer of glass to the back side as well.
Posted Image
Posted Image
the waiting game, my favorite part [not]
Posted Image
Posted Image
a little bit of "kitty hair" and a quick knock down.......now its starting to look like how i imagined it would
Posted Image
Hey look, NO MORE SCREW HOLES  :)
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
here is how it will look if your walking up on it from far away....
Posted Image
that'l do it for this weekend......more to come as it happens!
here is todays progress......
May seem like the same ol' stuff but its the little things that kill you on time.  I spent most of the day sanding the rear peice and fastening the box to the "shroud" that sits in front of it.  It took time to seal the cabin from the rear of the truck as well.  After that i turned the system on to see how it sounded finally completely sealed off and i noticed the box was flexing in the area of that front "chamber" where all the subs were facing.  Well everything i planned had to be put on hold while i fiberglassed the entire top with 3 layers of this super thick mat i usually use.  Now its very strong.
First things first, had to use these 20ga steel brackets i made at work to hold the shroud firmly against the box.  I planned on just screwing it to the front but i couldnt even get my angle drill in there so i had to improvise.
Posted Image
Time to start sealing it all off.....damn wires in the way
Posted Image
A little strip of foam stuffed into a crevice and dynamatted over
Posted Image
Posted Image
Posted Image
i suspected the grooves i carved to run wires thru had contributed to the box flex.  They are only 1/4" deep but it had to be a weak spot.  I decided to "kitty hair" all the grooves solid and encapsulate the wires into the box for good.......
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
