tripsicks Posted March 20, 2017 Report Share Posted March 20, 2017 So I'm looking to run 1 dual voice coil subwoofer, at about 2500 watts.. have a few subwoofer choices laying around, Dual 1 ohm coils, and dual 4 ohm coils so 2 ohms is my end ohm load in most cases. Currently have 1 Rockford Fosgate T1500.1bdcp, my options at this point for more power are to get a second T1500.1bdcp, and try to gain match them, running one amp per coil, or to get a T2500.1bdcp- My main concern is that the T1500 is not "linkable" or "strap-able"- my question is, is it safe to run 1 amp per coil if they are "gain matched" or is it better off to just grab the 2500? the bdcp amps are the only amps i'm interested in running in my truck at this time, strictly for matching my 4 channel and the mounting location they allow me to use. Link to comment Share on other sites More sharing options...
Jessica Posted March 20, 2017 Report Share Posted March 20, 2017 yes Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 21, 2017 Report Share Posted March 21, 2017 Gain matching would work on one sub. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
