FI Audio X series 10"
On 5/23/2017 at 8:56 AM, Keith77 said:
do you know the mounting depth?
From the site...
The X Series of subwoofers is our all around daily sub. We offer the BP option (a machined compression plug), for increased cooling and higher thermal powerhandling. A multilayer foam surround is attached to a fiber impregnated kraft pulp cone which helps keep things under control in high power applications. A 3″ 4 layer aluminum voice coil yields 20mm of Xmax while keeping the motor force high. The X series will work in most enclosure types (sealed, ported, bandpass). Light weight and versatile, the X Series works in a variety of applications from incredibly detailed sound quality systems, to ground pounding multi sub monsters. It comes standard with a white Fi logo on a rigid pressed kraft cap with the option of our hard dustcap and choice of colored Fi logos.
BP: “BP” option which was a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also added 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack. All of these features increase power handling from 200-500 Watts depending on the application.
Features
X10
DUAL 2 | DUAL 4
Fs: 32.5 Hz | 32.5 Hz
Re: 1.4 Ohms/coil | 2.8 Ohms/coil
Qms: 6.01 | 6.01
Qes: .48 | .48
Qts: .44 | .44
Mms: 162g | 162g
Cms: 0.00mm/N | 0.00mm/N
Sd: 310cm^2 | 310cm^2
Vas: 19.66 l | 19.66 l
Spl: 83.3dB 1W/1m | 83.3dB 1W/1m
Bl: 14.01 N/A | 19.81 N/A
Xmax: 20mm
Rms: 750W
Sealed box: .2-.4 cuft
Ported box: .6-1.2 cuft @ 33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 6.000”
Displacement: 0.07cuft
X Series: 10”, 12”, and 15″
Dual 2 and Dual 4 Ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3” diameter 4 layer coil
Single high grade magnet
Triple progressive spiders
Optional BP Cooling
Thanks for the interest!
Sale pending on 2 of these.  Will sell in pairs till gone.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
2 sold 10 left bump
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Features
X10
DUAL 2 | DUAL 4
Qms: 6.01 | 6.01
Qes: .48 | .48
Qts: .44 | .44
Mms: 162g | 162g
Xmax: 20mm
Rms: 750W
Sub OD: 11.000”
Cut ID: 9.250”
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Optional BP Cooling
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
bumpety
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
TTT
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
4 sold 8 left bump
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
8 left bump
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
TTT
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
bump
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
TTT
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
  • Who's Online   0 Members, 0 Anonymous, 1717 Guests (See full list)
