Wil84 Posted April 25, 2017 Report Posted April 25, 2017 What's the best to use in my system. And whats the difference between the two.
ShadeTreeMechanic Posted April 25, 2017 Report Posted April 25, 2017 Most people use both. A crossover will separate the signal from the head unit into separate signals like sub, mid, and high to different amps so the different speakers get only the frequencies they are capable of playing. An equalizer can boost or cut specific frequencies of the signal from the head unit. Some head units have these built in. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
