THE BASS LOVER Posted April 27, 2017 Report Posted April 27, 2017 So I had bought a Crown XLS 1502 and I have low output when using it with my yamaha receiver it's too low to enjoy it without making it sound like the gain is too high if you know what I mean by that the noise you hear when gain is too high and not enough sound is there a way I will be able to bring it up by alot so I can play really loud and sound clean?
ShadeTreeMechanic Posted April 27, 2017 Report Posted April 27, 2017 I use a preamp on my berringer inuke for that very reason. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
THE BASS LOVER Posted April 27, 2017 Author Report Posted April 27, 2017 8 minutes ago, ShadeTreeMechanic said: I use a preamp on my berringer inuke for that very reason. But here's the really weird part I have a crown xli 800 that i've been using for almost a year now and it is way louder on the same yamaha receiver they are both on .775 sensitivity but crown claims that the xls 1502 has 350 @ 8 ohms, 525 @ 4 ohms, 775 @ 2 ohms, well I don't think that is true not even close I had to have it half way just to get some sound when using it connected directly to my computer using rca I think there's either something wrong with the amp or it's a really bad design?
ShadeTreeMechanic Posted April 27, 2017 Report Posted April 27, 2017 Do a search for balanced and unbalanced signals. Your source has an unbalanced output and some amps can take either type. Some amps need a balanced input. You can buy a converter to take the signal either way. https://www.parts-express.com/rolls-mb15b-promatch-balanced-unbalanced-converter-35mm-rca-xlr--245-1062 I hope the link works. I am doing this on my stupid smart phone. This is what some people use. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
