crownvictoria31 Posted May 9, 2017 Report Posted May 9, 2017 I would appreciate help with this. So here are the amps I have and the fuses. Rockford fosgate R600x4D (Tweeters) Rockford fosgate r1200x1D (subs) Stetsom ex3000 eq (mids) NVX XCAP10 cap/distribution block Big 4 under the hood done with 2/0 gauge wire. and a single run of 1/0 gauge wire to the trunk. None of the amps listed come with fuse. I understand that the 600x4 is asking for 60amp fuse and the 1200x1 for 100amp fuse. This is as per the manual specs.As per the stetsom amp, I have no clue. What I would like to know is, can I just mount one fuse under the hood after the battery straight to a distribution block in the trunk and not worry about fusing in the trunk or should I fuse in the trunk as well? As per the distribution block, I am going to use the cap for this. Its a very nice piece.
crownvictoria31 Posted May 9, 2017 Author Report Posted May 9, 2017 Just found my answer. So as per crutchfield, if amps don't come with fuses, I must install one before the amp. So one right after the battery under the hood and one in the trunk right before the amp.
Rich Schenk Posted May 9, 2017 Report Posted May 9, 2017 12-18 inches from battery same for amp On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
