412Mark Posted May 22, 2017 Report Posted May 22, 2017 I'm looking to put a single 12 in my trunk. Per ami suggestions I need 3 cubes with 54 square inch of port. I have height of 15 1/4" and max width and length of 30" each.
412Mark Posted May 22, 2017 Author Report Posted May 22, 2017 Forgot to say I wanted it tuned to 34-35 hz
ShadeTreeMechanic Posted May 22, 2017 Report Posted May 22, 2017 What kind of power and what vehicle is this going in? I am sure that Joex and Triticum are around here somewhere. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
412Mark Posted May 23, 2017 Author Report Posted May 23, 2017 It will be in the trunk of a cobalt and I'll be running an aq2200 at 2ohms so about 1k power. I'm guessing box will sit towards the drivers side with sub facing across the trunk to the passenger side and the port to the rear. Unless you guys feel there is a better way
