Christian Murace Posted June 1, 2017 Report Posted June 1, 2017 Lets just say if i have a 2 ohm DVC Ground zero subwoofer , could I power each coil desperately from the same 2 channel amp? would the speaker not care? thank you
ShadeTreeMechanic Posted June 1, 2017 Report Posted June 1, 2017 That would work fine. You could even power each coil with a separate amp if you wanted to. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
