Box design help for 1 12.2 HCCA
1 hour ago, notorious97200 said:
That's what I would do.
I'd try 2 (max 2.5) cu Feet : that should be enough.
That's what I was figuring. 2-2.25. But I'm not familiar with that sub
05 TL build log SOLD
Well you can break out winisd and model and see what the port velocity is looking like with a single 6". With that much power, in a small box, it's going to be a pain to get proper port area, always is with high power, and small boxes.
With an Aero what kind of velocity would I be looking to be around?
32 meters per second for minimum port area, 22 for optimum. I generally just stay under 30
30 minutes ago, IKnowImLost224 said:
Okay thank you sir. With WinISD is power taken into effect? I remember trying to model a setup before and didn't see any change when I added the power
Yes, WinISD takes into consideration input power.  You have to put in your input power for the port velocity graph to have any relevancy.  The graph you want to be looking at is "Rear port - air velocity".
Builds:
Also if you input 3000w it might show high velocity. But realistically will you ever see a true 3000w with impedance rise and vehicle electrical taken into account? Most likely no so try a more realistic power input number
  • Who's Online   0 Members, 0 Anonymous, 1242 Guests (See full list)
