Ratski Posted August 17, 2017 Report Posted August 17, 2017 hi im curious if there is a member or a referral shop from a member that can recone a sub for me. the sub is ready for the recone, old cone is removed and i have my new recone kit. looking for someone to help me or do it for me obviously not for free. let me know. not sure if this is even the right section
ShadeTreeMechanic Posted August 17, 2017 Report Posted August 17, 2017 What kind of sub is it? Would you be willing to do it yourself? There are tons of videos about how to do this on you tube. As long as you have the correct parts it shouldn't be too bad. We can help you if you are willing to take pictures of the process and post them up in a sub recone thread. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Ratski Posted August 20, 2017 Author Report Posted August 20, 2017 i have a FI ssd 10. i have my recone from FI i just dont want to f it up. i got all the stuff talking myself into doing it myself but like i said i dont want to f it up and have to get another recone and at that point might as well have bought a new sub
Ratski Posted August 20, 2017 Author Report Posted August 20, 2017 its ready to be re assembled. i watched a handful of youtube videos and it didnt seem too hard.
bluethunder Posted August 20, 2017 Report Posted August 20, 2017 Nice Job on tackling the recone yourself. The first time is definitely nerve racking.
ShadeTreeMechanic Posted August 20, 2017 Report Posted August 20, 2017 Don't forget to take pictures for us. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
fox_racin4 Posted August 20, 2017 Report Posted August 20, 2017 as long as it is shimmed properly, youll be golden. what version SSD? ive got a few 10" recones here... 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Ratski Posted August 22, 2017 Author Report Posted August 22, 2017 On 8/20/2017 at 8:13 AM, fox_racin4 said: as long as it is shimmed properly, youll be golden. what version SSD? ive got a few 10" recones here... its a d1, flatwound wirh internal leads. the one that blew was the same but with cooling and high qts. there was not an option for that when i ordered so i just put it in the notes On 8/20/2017 at 8:13 AM, fox_racin4 said:
Ratski Posted October 26, 2017 Author Report Posted October 26, 2017 sorry for the no response on this fellas. my wife had our daughter, we moved and i have been slammed at work. im going to get a new head unit this weekend. and i will also most likely do my recone. its all prepped and ready just havent put it back together
Ratski Posted January 15, 2018 Author Report Posted January 15, 2018 ok on a serious note i totally screwed up... i was almost done with the recone... put on my dust cap and forgot to pull my shims!! so what you guys think? think i can carefully cut my dust cap out with a dremel and jimmy a new one over the top of that one?
